Is the condenser unit engineered to be optimal with a leaky cabinet? Any reason not to pimp it up, blocking air leaks?
While I was troubleshooting my 12+ yo Carrier AC this morning, I vacuumed out needles and debris that had built up on the floor of the condenser cabinet, and noticed that the cabinet is a bit leaky, with passages that allow air to bypass the condenser. Examples are the gaps between the condenser coil/radiator and it's cabinet, and several unused OEM holes, and several un-grommeted in-use holes.
https://i.sstatic.net/3TELb.jpg
https://i.sstatic.net/TpHCR.jpg
https://i.sstatic.net/dNHKq.jpg
FWIW, the canine pee pee corrosion blocks 10-15% of the condenser.
On another note, unless best-practices have changed, I will put some pipe insulation inside the cabinet around the low-temp low pressure refrigerant line.
