Possible Duplicate:
Is it ok to have mixed grounds and neutrals on bars in a breaker box?
I've recently opened my breaker box to connect a new line. I found that all the wires that go into the house are connected such that hot is interrupted through the breaker, and both neutral and ground are connected to the same (very long) terminal strip. I do have real ground (earth rod). The wire from the rod is just connected to the same strip.
My understanding that it's best if the ground is separate from neutral. How concerned should I be about this, i.e. how urgent is it to separate ground from neutral, if should be done at all? There is this question : Is it ok to have mixed grounds and neutrals on bars in a breaker box?, where the answer is that ground and neutral should be connected together, but only at the main panel. But I would like to understand WHY as well.
Also, I thought the latest code requires that all three lines are interrupted by the circuit breaker, how "bad" is it if only hot wire is interrupted?
Pawel Veselov
  • 205
0 Answers0
