I will be adding moulding and trim to a few rooms after I lay laminate flooring. I have already done this in one room and I was really discouraged with my miter cuts. In most corners, I had a gap of at least 1/4" that I had to fill with caulk even though I set my compound miter saw to 45 degrees.
Does anyone have any advice on cutting better corners?
Aarthi
  • 1,143
michaelkoss
  • 285
Keep in mind that for inside corners, you shouldn't be using miter cuts at all -- you should cope them instead. That gives you a joint that appears mitered, but is more forgiving of slight errors and with less tendency to open up over time.
Mike Powell
  • 9,394
  • 25
  • 43
There are two possible causes for this:
  1. Your room's corners aren't exactly 90°.
  2. Your mitre saw isn't accurate.
Given you mention you are using a compound mitre saw I'm going to go with the former.
Unfortunately with non-square rooms you're going to have to do this by a little bit of trial and error. Use some offcuts of the moulding or even scrap wood to find the exact angles you need and then transfer those to the actual pieces of wood you are going to use.
ChrisF
  • 16,973
  • 74
Are you cutting with the board standing up in the saw like it will be positioned in the room, or with the board laying flat in the saw and using the compound setting to cut it? The reason I mention it is that I once borrowed a saw and it just wasn't as accurate using the compound setting (saw tilted). Swinging the saw left or right, there is usually a detent at 45 degrees and the saw is more accurate.
If you board is too wide, you may have no choice other than lay it flat and use the compound feature.
Brian
BrianK
  • 5,475
  • 38
