I recently demo'd a bathroom that was using a "rustic farmhouse" galvanized shelving unit. I took this unit off and was hoping to re-install. Ideally, the elbows would thread in so when they are tight, they are exactly 90-degrees upright, making the shelf level (pic 1 + 2). The problem is... they don't. If I tighten them to the point where they would support any weight (pic 3 + 4), they are going in complete opposite directions and will not work.
It used to be 90 degrees.... I can't figure out for the life of me how they did it.
Is there some sort of discrete nut or washer or something I can use to tighten these and still determine the angle? Am I using a glue/adhesive of some sort? What's the trick here?
RCNeil
  • 267
Assuming that they are threaded in correctly, you just need to apply adequate force. Pipe threads are tapered to make a seal (which you don't care about in this application) but there is considerable latitude in how far they can be tightened, with proper pipe wrenches (always use two.)
Otherwise, you can add unions to get exactly the angle you want, but the normal approach (particularly when you don't have to make a seal) is just to get them tight enough, and then crank it up more to get them aligned. You have to really overdo it (or start cross-threaded) to seriously damage the threads.
You MIGHT find some benefit in using pipe dope (as for sealing) since it will provide some lubrication, without being all slippery like grease or oil. i.e. It's designed for the job at hand.
They don't hold pressure so they do not need to be tight. Just stop turning when they are in the right postilion ; basically tighten then back off to the desired position. I have even done this with pressure to a limited degree.
blacksmith37
  • 8,401
