My gas furnace is located in my laundry/utility and is normal(~80%?) efficiency with a Type B Flue. It goes up through the drywall ceiling into my attic(1 story) and out the roof and I verified that there is no insulation in contact. There is a ~1" air gap in the drywall which is a draft leak and worse is pulling in a significant amount of combustion air from the attic.
I'd like to seal this gap and can't quite make sense of the best way to do this. I understand that no contact with combustible material within 1" is code for type b vent but what is defined as combustible is not clear.
The closest thread I can find here is this one for a range vent How do I air-seal a range hood flute?
But I can't easily slip on the collar so I was thinking I could cut a slit to bend it onto the pipe at the ceiling and then aluminum tape or firestop caulk the cut once installed.
Could I instead just caulk the gap with 3m fireblock which is noncombustible? Or is setting drywall compound considered noncombustible?
redlude97
  • 1,705
Theres also fire caulking, pretty expensive and you may have to close the gap if its very big. They do have collars that fit around pipe with a flat flange extending outward. The poster above suggested to. Be aware of hot items against combustable material in an attic, the dryness creates a tender box effect.
drose
Drywall is an approved fire stop. The 1 inch requirement is to wood or any material that can easily burn. Fire proof caulking and fiberglass insulation in attic will take care of problems. Provided you have enough combustion air for your furnace and hot water heater. Chalking can be bought from Home Depot
