16
On my GE dryer, a 3 prong cord is hooked up as shown on the picture. I want to replace it with a 4 prong cord I got with the standard green/red/black/white terminals.
I am a bit unsure of what goes where and why the ground is connected to white/yellow with a jumper on the current setup.
How would I hook up the new cord after having removed the old 3 prong one and will I keep that jumper from ground like it is now?
It was suggested that this answered my question: White wire when changing from 4 prong to 3 on dryer I read that but found it a bit confusing. The answers I got here solved it for me.
Christian
  • 769
Remove that brass jumper, connect white to the middle terminal, red and black to the one each of the two end terminals and green to the ground screw.
JACK
  • 89,902
  • 214
Jasen
  • 26,920
  • 46
21
The jumper from neutral to ground is exactly what makes a 3-prong cord so dangerous.
The jumper gets removed. The neutral wire lands on the insulated terminal (that was vacated) and the ground lands on the uninsulated end. I don't know if they provide a parking position for that strap to "live" when it is disconnected, but since 3-prong connections are obsolete and dangerous, I'd be thrilled to see it go away for good.
Really Code requires you to follow the dryer's UL-approved instructions (findable on the Web), however I'm pretty sure that's what the instructions will say to do.
12
Thank you for the photoshopped connection picture. Very impressive and helpful! Based on that information and illustrations I got here I ended up with what you see in the picture. I moved the ground connection to make it work with the cord I got. It works so I am hoping I did it right. I also hope the used GE dryer I bought will last for a year or two. Thank you all again!
Christian
  • 769
