Plumber found (what he called) a pin leak at the elbow. It has done considerable damage.
I want to know how this happens and if more of my pipes might be affected.
NOTES:
House is 20 years old.
I don't often use the bathtub this was connected to.
Pipe has a 10' horizontal run before the elbow redirects water up.
Edit1: Original setup with jacuzzi pump grounding.
Marinaio
  • 1,674
  • 48
That is corrosion due to flux residue from the soldered joints not being wiped from the outside or flushed from the inside.
There are several grades of flux and some are more aggressive than others - I use a very "soft" one for all tasks but make sure to clean both the pipe and the fitting, reserving the aggressive one for the very few joints that don't take.
Timeline is also about right - I had one go on me a few years ago. it weeped into a concrete floor for about 6 months until the evidence became visible.
Based on the evidence, there may be other joints being affected - check the ones that are visible. Note that some may have been cleaned on the outside as part of normal house cleaning, so find some under floor or behind cupboards etc to check.
Solar Mike
  • 30,038
  • 69
There are several reasons why copper pipes develop leaks:
  • When fittings are sweated with a torch, too much heat and flux can corrode and weaken the pipe walls.
  • Lately the copper that is being produced is subpar (in my opinion) to copper produced 15 years ago. Not sure if the forging recipe changed or if the wall thickness has been reduce, but it doesn't hold up well.
  • Hard water has a detrimental effect on the soft copper metal. Over time it will wear away the inside walls.
It's impossible to predict where a leak will occur. When a similar situation happened to a customer, I installed CPVC pipe to replace the leaking copper. Also after checking the water pressure, I found it to be very high (90 psi) and installed a reducing valve, which so far stopped any more leaks.
ojait
  • 11,108
Mazura added this as a comment, but should be a top answer: galvanic corrosion is an extremely common cause of pin-hole leaks in copper pipe, caused by direct contact between iron and copper. See: What is causing these water heater pipes to rust/corrode?
Normal fixes to prevent this are brass or plastic-lined dielectric coupling nipples.
Oblong2824
  • 1,484
Another possibility is Erosion Corrosion caused by disturbance to the flow in the pipe at the elbow. You have a large blob of solder that could cause disturbance to the laminar flow inside the pipe causing cavitation and erosion of the inside surface of the elbow. Subject to how much flow and how frequent, and whether the blob is upstream of the pinhole, you should consider the possibility.
For more information see the following link
elchambro
  • 151
