I'm building a room into our (existing) barn; how should I best go about insulating it?
The barn is a Morton building -- pole barn construction, metal siding. It's closed on three sides but open on the fourth, so it's not as much a closed-in building as a glorified run-in. The room I'm building will be against one corner, so two sides are defined by the walls of the existing barn, and the other two sides are framed up and built inside the existing structure. The floor of the room is a concrete pad; the rest of the barn is a dirt floor.
I'd planned on doing standard kraft-faced fiberglass, just like I'd do in a house. However, I've read that the moisture in a metal building can build up on the insulation and cause it to mold. I've certainly noticed that on certain days there's plenty of humidity that builds up in the barn (enough to cause water to condense on the inside of the metal siding).
So: is the fiberglass a bad idea? If so, what should I do instead? Should I do a moisture barrier on the outside of the room (between the framing and the metal barn sides)? Or...?
Michael Karas
  • 67,833
  • 68
  • 153
jacobian
  • 143
The links in the other answers are very informative!
In answer to your question:
The answer is yes, at least in the exterior walls.
You have a bunch of options, none as cheap as simple fiberglass batts. My personal recommendation would be rigid foam on the exterior walls and ceiling with fiberglass batts on the newly built walls. Pricey but effective.
Essentially, you're going to be building a little tiny insulated house inside the barn without the need to weatherproof it. At the risk of losing a few square feet of floor space, why not just build the room free-standing in the corner, with maybe a couple of framing attachments (e.g. longer ceiling joists) to the barn walls? That way you can do a simple wall with sheetrock both sides and fiberglass insulation in all four walls and the ceiling.
Jeremy Stein
  • 1,372
Paul
  • 872
Sounds analogous to insulating the interior of a basement wall. Rigid or spray foam next to the metal, then a stud wall with drywall, according to here: http://www.greenbuildingadvisor.com/blogs/dept/musings/how-insulate-basement-wall
http://www.insulation4less.com/Insulation4lessTechnicalArticles-49-Metal-Building-Insulation.aspx
This article seems to indicate that a product called "Prodex" isn't affected by humidity or water.
Justin Abrahms
  • 111
