I'm about to put a driveway down. Is it possible to cover the driveway with mulch instead of gravel?
Context:
  • In the woods. I want to keep the woodsy feel.
  • Long, mild winters. January average temperature is 38 deg F. Not much snow, and no plowing.
  • 19" rainfall each year, in the fall/winter/spring.
  • Glacial till subsoil.
Jay Bazuzi
  • 11,778
  • 100
  • 143
13 Answers13
You could, but it strikes me as a bad idea for a few reasons. First, you'll have to replace it every year (or at least every 2-3 years). Second, you'll get much better traction on gravel, especially when wet or snowy. Finally, mulch is much more likely to wash out in the rain, especially if it's only a shallow layer.
Eric Petroelje
  • 9,729
  • 42
  • 62
I would expect that mulch, when driven on repeatedly over a year's time, to break up into compost. Driving on any wood chips will gradually break up the fibers, as well as distribute things around. You will be improving the dirt on your driveway. In my case, I would not want that to happen, as it just encourages weed growth.
Another factor to consider is if you will need to plow. Do you get snow? A snow plow will make a mess here. Even shoveling snow will be tough.
However, if you have a steady (yearly) supply of mulch, and you like the look and never get snow, a mulched driveway will work.
I'd go with gravel over mulch. Wood chips can retain moisture and rot. They'll also keep your driveway wetter longer after a good rain. If your driveway has any slope to it, mulch would also get washed out more easily than gravel.
Even if you decide on mulch, some municipalities may not allow it. For example, if you live in Baltimore, you may get fined. On the other hand, the same article also mentions that other cities encourage mulched driveways, and even supply the mulch for free (it's hard to beat free!).
Doresoom
  • 15,873
  • 83
  • 122
I have to answer this because I did this about 15 years ago for an older relative. She wanted a dirt/mulch driveway for her suburb cottage. I tried to talk her out of it but she insisted. So I rented a bobcat for $100 and dug out a 12 foot wide section of her yard leading up to the patio. I went a good 10-12 inches deep and kept the edges pretty sharp. We laid down a ton of coarse mulch (tree service place basically said this was as coarse as they did mulch - get "tree chips" not gardening mulch which is actually more expensive) after I flooded the dirt area.
We used a truck and some old plywood to smoosh the mulch down. A roller would have worked better and faster but didn't have a roller. This was about 60 feet and total work time was maybe 12-14 hours. "Driveway" is in the midwest and goes through all of the seasons. She spends about $50 a year for not only the mulch but the tree service does a quick spread too.
Digging out her driveway increased drainage away from house and she loves her mulch driveway which goes with the house. You can't shovel it in the winter, but it doesn't ice up either. The sides have rounded and the driveway sits in about 6 inches. Maybe it will have to be redug in 10-20 years... Not sure it is messier either. The mulch doesn't stick on the bottoms of our shoes (and she makes us take them off at the door). The only downside I have seen is that I do get mulch in my shoes.
Is it better than a concrete driveway? No way in my opinion. But it functions and goes well with her house. Her cheapest concrete driveway bid was 8K. If you can invest that at 10% she has already made enough just on interest to buy 3 driveways.
DMoore
  • 50,637
  • 93
  • 208
First I live in Florida. No snow. I've had a mulch drive now for 6 years. I chose this over shell or crushed stone for dust controll. Its a lot cheaper and its much easier to spread. It does not compost as some of the comenters have suggested. If your goal is to look good at a price you can afford do it.
Gary
It sounds like you're aware of and willing to deal with the possibility that the mulch will break down and disperse more quickly than gravel, so I'm not going to harp on that.
The other reason I wouldn't personally be a fan of a mulch driveway would be the cleanliness. If you don't have a garage, I would think you and your guests will be tracking a lot of mulch particles into the house as you walk in from your cars, especially if it's raining and the mulch is wet. And if you do have a garage, your car's going to be bringing it into the garage. You could minimize this by having a gravel or paved parking area (or apron in front of the garage).
Mike Powell
  • 9,394
  • 25
  • 43
If the goal is keeping the 'woodsy feel', you may wish to consider instead looking at some of the 'green driveway' solutions. I wouldn't say they're cheap, but they're basically plastic to to help spread the load out, so you don't compact the soil too much, to support growth in between it. (with the idea that it then fills in, and you can have a driveway that looks like grass, although, in your case, you'd probably want moss instead)
Joe
  • 7,336
  • 48
It is possible to cover it with shredded newspaper, but I don't think you'd want to.
The first time a car goes over the mulch, most of it will be pushed aside, like snow is when a car goes over it. If the car goes too fast, it will be thrown up like a rooster tail. Soon enough, you'll have to replace the mulch. (This happens with gravel as well, but to a much lesser extent)
Chris Cudmore
  • 14,169
  • 61
  • 91
One factor noone else mentioned is fire safety. Just about everything burns well in certain conditions. And in the woods after several weeks of dry hot weather the last thing you want is a layer of dried-up mulch around the house.
sharptooth
  • 9,717
  • 65
  • 89
I have mulch in a part of my driveway. We recently had a 2 week stretch of rain, and now I have a nasty slop hole where the mulch is. I live in south Louisiana, by the way. The mulch was a good idea while it was dry, but the wet mulch is a very big mess. Don't do it, is my advice. I just got off the phone with the limestone man, and I will be putting limestone where the mulch is.
Coming from SE Nebraska, Snow, Ice, Low plains... I have done this every late Winter after last snow and it works beautifully to bill and temporarily raise the area where I park. It doesn't ice and every other year I have a beautiful compost process going on. It's not a muddy mess in the Spring. I use the sides that are not really broken down in the garden and it works well on my all-dirt driveway.. I guess it all depends on where you are and what you need...
Machavity
  • 26,498
  • 44
  • 100
At our last farm we used bark mulch (hog fuel) for several paths /roads that have daily tractor and horse traffic. It held up well and although we added a truck load about every other year the horses like it better than gravel especially after getting there feet trimmed. At this farm we only have about 200' the rest is gravel the advantages I see is no grass in the mulch compared to the gravel. One disadvantage is that the mulch holds water so if you need to get under a tractor or implement if it has rained in the last week you will get wet unless a tarp , board or cardboard is put down first (it always has rained in the last week in Oregon LOL).
Ed Beal
  • 103,727
  • 79
  • 158
Really nice to see a response from someone who has actually done it. Out of boredom and desperation, I once laid a bunch of mulch down in a large patch of mud that my husband used as a driveway to his shed/shop. Probably 20 x 20 area. It worked WONDERFULLY. It seemed to almost fuse with the mud and created a compact surface and that was with a fairly thin layer of filling in mud ruts and raking over the top for the rest.
Ms. J
