I have a single three prong socket in my wall for my washing machine. I would like to put a small lamp on the counter next to the washer but there are no other sockets anywhere in my laundry room. If I use a heavy duty splitter can I plug my washer in one socket and my lamp in the other or do I need to have that single socket replaced with a double one as I have seen on this website suggested before. I'm talking maximum of like 25 to 40 w lamp. Thanks
Just replace it with a duplex. There needs to be (current code, hasn't been that way "forever") a dedicated 20A circuit for the laundry room. But it can be a duplex receptacle, which would solve your problem much safer than a "splitter".
In addition, it should be GFCI protected according to current code. If it is not currently GFCI protected, then you should install a duplex receptacle with GFCI, solving two problems (safety and convenience) at the same time.
The only catch will be if the existing single receptacle is in a very small box. Small boxes can usually take a simple duplex receptacle but are often not big enough for a GFCI. If that's the case, you will need to replace or extend the box, which gets a little more complicated.
- 139,495
- 14
- 149
- 386
To answer your primary question, yes, you can use a splitter. It's marginally less safe and runs the risk of working loose over time, but some common sense makes it viable.
Just use one that looks well constructed, maintains the ground path, and meets the current rating of the circuit breaker.
- 158,133
- 9
- 190
- 463
