I am planning on getting an electric car in the near future - ordered delivery early next year. I park the car on the city street in front of my house. The city owns the piece of grass from the street to the side walk and a couple feet from the sidewalk to my frontage.
I think the best plan is to run a teck cable to a receptacle on my side and then use an extension cord via a conduit under the sidewalk to where I park my car.
I am currently working on landscaping and the pathway for the cable is under one of the trees I am going to plant.
Ideally if I end up with two electric cars in the future I can add another receptacle and put another extension cord to charge both.
I see that for Telsa there is a 90amp option.
Provisioning for a hypothetical electric car
I am not sure if there is a 90amp receptacle and charging cable. Not currently planning on telsa but be nice if I had the infrastructure there for the future.
Should I run conduit or tec cable? What size? I suppose at most 2x90amp options but I only have a 200amp service so I am not sure that makes sense.
For part of the run I already have 4" abs pipe as I had to install it before I built my window well and the window well is where I'd have the tec cable enter the house ( under ground ).
I talked to my electrician about it and he thought 60amp aluminum to a receptacle - that was before I read the about the 90amp telsa answer.
Looks like there are 30' extension cords so as long as the path from my receptacle under the side walk and close to my car is less than 30' I should be good.
It seems like level 2 charge is 50amp so I'd be looking at a NEMA 14-50 Receptacle and then I just need to figure out how to waterproof and make it look nice since it will be on a post in my landscaping.
The default is probably something like this lockable enclosure. The harder part is making it disappear into the landscaping.
Thank you !
Fresh Codemonger
  • 14,459
  • 57
The largest standard size, reasonably priced, receptacle you will find is 50A. 40A uses the same receptacle. Depending on how much service you have, how long the cord will need to be, how much you want to spend, and how much charging you really need, it may make sense to install a 40A or 50A receptacle (same receptacle, but different wiring requirements) or you may be perfectly fine with a 30A receptacle. Or even 20A, but once you're going to all this trouble I'd recommend going for 30A (50% increase in charging speed over 20A). Tesla rates a 30A connection (24A actual current draw) at 17 to 22 miles per hour of charging, so an 8 hour charge gets you 136 to 176 miles of range, which is enough for most people unless they have a really long commute or are out driving Uber/Lyft all day.
  • 139,495
  • 149
  • 386
Not as pretty, but if you could get an easement to allow permanently installing a pole curbside (city land), or if there is a electric pole next to your parking spot, get permission to add wires to that, you could run overhead wiring to the charging port.
Carl Witthoft
  • 4,012
