UPDATE:
I was able to wire a C-Wire to the Ecobee. So now I got 24 Volt at the Ecobee. But it still won't run.No sign of action at all. Maybe because I got no green connection? Any ideas?
We relocated from Germany to the US and with the upcoming Autumn I try to make improvements on our temperature management. Our house has three zones with two furnaces. The single zone I was able to connect to an ecobee, although there was no C wire. But the PEK terminal that came with the ecobee helped me with that.
The other two zones are connected to the Mastertrol Mark V. For I got very limited knowledge about this system I better ask:
There is a cable (5wire)connecting the MarkV and each Thermostat. I hope that RWY are connected according to the typical scheme in these systems. If so I need C and Green. The wires are there hanging around the Cable.
I wonder if:
I can grab C from 1 or 2?
I can get green by connecting to the green cable on the left?
Maybe a stupid approach but hey! 55 years we had a water based heating system - this is 100% new to me….
Ot another approach: any idea how to wire that?
Any help is well appreciated!
Wiring Diagram
Yes, 1 or 2 should provide a C (measure for 24v against R in each zone). And G may be accessible from the left-sided terminals. But you need to provide more pics of the actual wiring and a better description of the entire set up for a more thorough answer.
There was also a previous thread with this system:
Connection for C wire on Mastertrol Mark V zone control panel
diy_coder
  • 54
