I have purchased a new Tesla model Y and figuring out options to install a home charger in my garage.
Issue: I live in MA and I do not have a basement or crawl space. My circuit panel is on the ground level in a room adjacent to garage but at least 30ft away from the garage wall. Question: Is there a way to run a wire from panel through the wall and to the garage?
If the above is not possible, I did some research and came up with the below solution. Please advice if I should consider this or what would be most cost effective solution.
Potential solution (need you opinion here) I have my dryer inside the home but adjacent to the garage wall. The dryer is on a 30A circuit with a 10-30 outlet. I am thinking to use a voltage splitter (https://splitvolt.com/products/splitvolt-safety-certified-splitter-switch-nema-14-30-14-50) and use the existing 30A circuit to charge both my EV and also run the dryer. This splitter has the ability to switch full power and also has a safety breaker if my EV tries to draw more than 24A. I think all I have to do is make a hole into the garage wall and pass the 23ft EV charger wire through it. this setup will force me to charge my EV at 24A to protect my circuit and wiring which will give me about 18 to 20 MPH. I am fine with this because I plan to move soon.
Please advice if there are any flaws in this setup Or if you think I should consider any other cost effective option.
This question is probably asked and answered but I can not find it.
Thank you.
