I have a wall-mounted cupboard that I bought some about 7 years ago. It has a lift-up front face which is driven by a KESSEBOHMER hinge mechanism. The face falls when lifted, apparently a common issue that can be fixed by strengthening the spring inside. Unfortunately I could not find my exact one in their catalog.
It looks like this:
There are + and - indications. The ones on the right, next to the screw, are there to fine-adjust the height of the mechanism - when turning the screw the whole system moves up or down a bit. I do not know what the other +/- (the one on the left) means.
I wanted to ask if someone has ever adjusted this mechanism before? The thing that worries me is that I do not see any visible way to adjust the force of the spring.
EDIT: the two holes on the left of the two screws (the lower one is also on the right of the quasi-vertical ← + - → sign) are just mounting holes for the cover that comes on top of the mechanism. They are empty.
EDIT: the piston is a breaking mechanism to slow down the falling facing, it does not take part in maintaining it lifted (I checked that on the other, correctly working hinges)
