I have a pump that is 350 ft from my house. Here are the specs for the pump:
Rated power - P2: 1 HP
Main frequency: 60 Hz
Rated voltage: 1 x 115 V
Maximum current consumption: 8 A
Power plug: US plug 115V
The breaker is a 20 amp GFCI breaker (I can't seem to find good GFCI breakers that are Square D larger than 20 amp). I know from calculators that I need larger than 10/2 wire, but I ran the 350 ft with some 10/2 ufb wire anyway, to see if it would work ok. I did this because I already had the 10/2 wire. It works intermittently, but I've stopped using it because I don't want to damage anything. I'm getting mixed signals based on which electrical calculator I use saying I either need #6 or #4. Wire's insanely expensive, but I need this pump working.
I know there are other alternatives like running 240v, but I can't seem to find a step down to 120v that will be happy in an outdoor environment. So, ignoring the fact that I could run 240, with a step down, how can I accomplish this?
Is it ok to keep the 10/2 on both ends (since the wire is about as small gauge as I can get and still get it inside the boxes I need easily) and splice 300+ ft of #4 or #6? I'm not sure how the splicing would effect the run.
And assuming splicing is ok for this.....since it's hard to find 500ft 6/2 wire in ufb, and I need 300ish feet, would it be ok to buy a few 125ft lengths and splice them?
