I asked this question here and got some great answers. As mentioned in the previous question I have a pump that is 350ft (as the wire runs, probably closer to 370ft) from my house, that pumps water up my hill. The specs for the pump are as follows:
Rated power - P2: 1 HP
Main frequency: 60 Hz
Rated voltage: 1 x 115 V
Maximum current consumption: 8 A
Power plug: US plug 115V
I've decided to do as the answer on that question suggests, and use a 2 pole 15 amp breaker, and run the full 350 ft using 12/3 cable. Then I need to step down from 240V to 120V since that's what my pump uses, and I want to plug a few other things in at the bottom of the hill (everything other than the pump is super low draw, like LED lighting).
I can find step down transformers all over online, but nothing that seems right based on the answer from the original question. They recommended a
a small encapsulated (NEMA 3R rated) 240V/120V stepdown (1500VA is fine)
I've gone to a few electric stores this morning, and nobody seemed to know what that means (admittedly, I am not an electrician, and neither are the guys working the counter). However, they did have Hammond control transformer 50 VA, 1-phase, 120/240 VAC panel mount. They had these in many different VA's including 50 VA, 100 VA, 350 VA, 1000 VA, 1500 VA, etc.... Other than these, I can't seem to find anything that is already encapsulated in weatherproofing (unless the price jumps significantly...like, from $100, to $800.)
It's likely I'm not looking for the right thing, and could use help on suggestions on what kind of step down I need. I don't mind mounting one of these in a weatherproof box, but I'm not entirely sure which VA I need. I know the original answer said 1500VA, and that one does exist in a store near me. But, is this the right thing to get, and then just buy a waterproof box for it?
EDIT
This one meets the description given in the original answer, but I was a bit confused because it seems cheaper to get this one inside of a case, than outside of the case.
