24
It has just recently started raining where I live, and I am new to this house. When the rain ceases and the water is dripping from the gutters through the drain, I can hear the dripping from inside the house. It is REALLY loud and is driving me crazy. The gutter drains are right outside my bedroom and the living room, so getting away from these areas is not an option.
Is there a way to get rid of (or greatly reduce) the dripping noise?
Aarthi
  • 1,143
Jeremy White
  • 829
6 Answers6
30
I'm surprised the dripping is that loud but there is a simple solution. Drop a some rope, such as heavy sash cord, down the drainpipe and attach top end in such a way that at least a couple of inches of the rope is sitting inside the gutter itself. The way this works is that the water will tend to run along the rope, which should ensure the water runs along the wall of the drainpipe instead of falling through the air.
John Gardeniers
  • 1,745
Stick a sponge at the bottom the drips will land quietly on it and when it pours the water still flows through.
ChrisF
  • 16,973
  • 74
Charlie
  • 61
Here's a VERY simple solution.
I've had this problem for over a year and it's been driving me crazy. I finally found an incredibly simple solution, and it's especially good because I'm in an apartment where I'm not supposed to be "fixing" anything anyway.
Take a scrap piece of wood and wedge it between the building and the pipe at or slightly above the elbow that has been causing all the noise. This should move the elbow away from the building about 1/4" to 3/4". If it's anything like my place, the noise will stop immediately. Now the water drops land silently on the side of the pipe about 6" above the elbow, instead of slamming into the bottom of the elbow.
It's probably best to do this fix while the noise is happening so you'll know whether it works for you or not.
  • 20,909
  • 95
  • 135
Chris
I found a pretty good way of stopping the noise. I cut some 5 mm thick rubber to the same width of the gutter then slid it in so it went just past the angle. It has poured down and they still run freely. So I hope this works for you.
chris
Try cleaning your gutters and down spouts, then instead of dripping through, the water would run out in a stream, making less noise and getting done quicker.
Zach
  • 1,555
Make sure the outlet on the gutter is touching the side walls of the downpipe.That will also insure the water running on the inner wall af downpipe and fall down the centre.Is it aluminium?
