I really am not a fixer type of gal but this seems like it should be simple enough. Please respond appropriately for someone who has limited knowledge.
I have a hanging outlet in my horse barn. It seems to be properly wired per a contractor friend. All wiring enclosed in conduit, etc. The only problem is, it appears that this outlet box has lost its seal? The front plate is coming off (where the outlets are) of the rest of the box. There are no screws that can be tightened to fix this. The box says on it "For use in wet or damp spaces, use sealing compound to seal."
Okay, but what type of sealing compound? And do I apply it around the edges?
Don't worry, I know to shut off the power to the barn prior to fussing with anything electrical.
user14488
  • 61
Silicone caulk works wonders in all kinds of situations. The screws that are missing to hold all parts together can usually be replaced at any Home Depot or electrical supply store for just a few cents per ea. The hanging outlet box I have seen used several times in barns, however if a 2 by 4 can be attached to a ceiling crossbeam and placed perpendicular to those beams it will offer more stability to the box and wiring. It can be installed high-up still rendering it useful and out of the way of any horses but will provide more stability to the whole thing.
  • 20,909
  • 95
  • 135
user20316
I think I know what kind of outlet you have, but I am vexed trying to find a photo of one online.
It is a thick flexible cord hanging from the ceiling or a joist with a strain relief—like coiled spring-like wire with an outlet box at the end. Maybe the cord has some flexible coils or other means for adapting the height of the outlet above the ground.
To seal this, clear silicone caulk is more than sufficient.
wallyk
  • 12,399
I agree with the above answers that the box should be secure to a beam or post. The outlet then has two screws that hold it into the box. Finally there is a center screw (or with a GFI type receptacle - one at each end) that holds the cover over the receptacle and sandwiches a soft gasket between the cover and the box. Since this is an installation over a wet area, it must be a GFI (ground fault) receptacle to be safe.
mike
  • 3,080
MasterE
