I recently installed a run for a mini-split from my panel to a disconnect box. The run is 12/3 NM-B cable from the panel, under the house in a crawlspace suspended from a rat track, through a hole in the siding to an L-fitting on the exterior, then exterior to 3' of PVC conduit, then to the disconnect.
To be clear, the parts that are exposed to weather are the L-fitting, PVC conduit and the disconnect. These are all less than 3' from the mini-split.
I'll add that the crawlspace is tight, considered nominally 'inaccessible' (I managed it ok, but someone more rotund than me would not.) This rules out a crawlspace junction box to transition to THHN.
Given that the exterior parts of the run (L-fitting, PVC, disconnect box) are exposed, they are considered 'wet', and thus not allowed for NM-B, right?
I realize it's a bit nit-picky, but I'd like to know how can I make this run code-legal.
I was considering enlarging the hole in the siding to fit a junction box, transitioning to THHN inside this box to a flush-mount wet location outlet box, then making the run from the outlet to the mini-split disconnect. Then I get a utility outlet for my trouble.
Would what I propose be compliant? I'd rather do that than re-run this with UF or THHN in conduit all the way back to the panel.
