12
When putting in a new switch for a light it is often less work to put in a smart switch than run the mains cables.
However, how do you choose the type of smart switch to use?
See also "What are the pros and cons of different types of smart switches (That are on the UK market)?"
Walker
  • 6,275
  • 66
  • 87
X10
  • Pros:
    • Many manufacturers, and wide variety of products are readily-available (As of 2012, this may not be the case any more)
    • Low-cost
  • Cons:
    • Old protocol (circa 1975)
    • Most devices communicate over power lines, and design makes it susceptable to interference from noise. At worst, noise can be interpreted as commands (causing lights to turn on).
    • Slow and fairly basic. Sending more than 2 or 3 commands takes a couple seconds.
    • Only supports 256 addresses per network (total number of discrete dimmers, scenes, and sensors combined)
    • Requires phase-couplers to bridge both phases of power together
    • Requires PC or special hardware to program
  • Products
    • Smarthome makes fairly decent quality switches, which support scenes (multiple devices responding to a single address).
Insteon
  • Pros:
    • Relatively low cost compared to other products on market
    • Decent quality switches
    • Basic linking (including scene programming) can be done using devices themselves, PC-based programming for more advanced control.
    • Each device has unique address (16 million possible), and supports
    • Hybrid powerline/wireless: many devices use both to communicate, and most devices repeat signals to increase coverage/signal strength
    • Easy to interface to other products due to market size:
      • There are even several iOS apps that can control Insteon if you have an ethernet bridge
      • Most home automation controllers can communicate
  • Cons:
    • Swapping out a device can be difficult due to addresses being hardcoded (need to reprogram all other devices that were controlled by or control the swapped device)
    • Some strange limitations in scene programming (eg, cannot program a scene that sets some devices on, and others off)
  • Products
    • Smarthome makes a wide variety of products and is also the designer of Insteon
UPB
  • Pros:
    • More reliable protocol than X10
    • Simply-Automated's switches (at least) are extremely flexible:
      • Can configure 1,2,3-tap and press-and-hold behaviour for every button
      • 8-button switches are configurable with interchangable faceplates to be anything from a basic dimmer to 4 dimmers or an 8-button keypad or almost anything in between
  • Cons:
    • Uses power-line carrier, so it requires phase-couplers to bridge both phases of power together
    • Complex to program, requires PC software
  • Products:
    • Simply-Automated makes switches, plug-in modules, in-line modules, I/O connectors and computer interfaces
Z-Wave
  • Pros:
    • Wireless, and each Z-wave unit acts as a repeater, so the more devices you add in your house, the better coverage you get.
    • Standardized and easy to D-I-Y, you don't have to have it professionally installed
  • Cons:
    • Still a technology 'maturing', so you might have to be a bit of a hobbyist to get it all to work correctly.
  • Products:
    • Thermostats by Trane and others
    • Light switches by GE and others
    • Locks by Yale, Kwikset, and others
    • Controllers by many vendors, either PC-based (Homeseer, z-wave.me) or separate devices (MiCasaVerde, Homeseer)
gregmac
  • 29,300
  • 89
  • 162
The lower end stuff is crap, and will drive you mad over time. This includes X-10, Insteon, and UPB. These products will fail. It's just a question of how long before they do. Z-Wave is a technology, not a product line.
If you want something complete and reliable, go for Lutron RadioRA. Version 2 of this industry-standard system was released recently, and prices have become more reasonable. This is a whole-house solution. They also offer single-room and smaller-scene packages, and the mother-load solution called HomeWorks, which pretty much rules out retrofitting.
http://www.lutron.com
Note that you'll want a pro to install and configure these switches, unless you're really geeky and comfortable with handling electricity. And single.
Edit: Here is a link to a discussion about this very thing on a pro site. Read the comments: http://www.cepro.com/article/hardwired_vs_wireless_lighting_control/
Josh
  • 381
