35
I have a older home (build in the 50's) with 1/2" dry wall and then plaster on top.
I would like to run Cat6 cable through most of the house (living room, kitchen, entertainment room,etc).
So, I'm looking for pointers on how to do this.
At first glance, I could make a fairly long 'horizontal trench' in the wall, through the plaster and dry wall and then run the cable through the studs (they are wood and I would have to drill a hole).
But I'm really hoping their is a better way.
edit
I also have a finished basement (except for the furnace area).
Aarthi
  • 1,143
cbrulak
  • 761
8 Answers8
40
Go big or go home. If you're going through all the trouble to pull wires through existing walls, don't pull just one. It's only slightly more work to pull two wires than to pull one. Doing the project a second time in a few years is twice as much work, though!
Think about everything you might want (IP networking, surveillance cameras, cable or satellite TV, telephone, speaker wires, home automation control signalling). Then add a bunch of extras. Cat-6 is a good choice, because it can carry most things you might want.
Consider a single conduit. During a major bathroom remodel & replumbing job, I had the plumber put conduit from the attic to the "wiring closet". He went a little nuts, putting two 4" conduits in - one for high voltage, one for low voltage. This makes it relatively easy to add a new service anywhere. Unfortunately, this was after I had finished running structured wiring.
Since a small part of your basement is unfinished, you might want to run conduit from there to your attic, and make that your "wiring closet". Then you can pull from each outlet to the attic, and easily run it down the conduit.
Star topology. Pull everything to a central location, and patch them together there. I used the space under the stairs.
How to pull up to an attic: In your attic, drill a large hole in the sill plate. It should be big enough to fit all the wires you want through it, but small enough to keep the strength of the sill plate. Avoid the wall studs below.
Cut a hole in the wall below, for the outlet.
Push a fish tape down from the attic. Have a helper watch the hole for the tape, and grab it with a bent coat hanger. They attach the wire bundle, and you pull it back up.
To push/pull from attic to basement, you can cut a hole on the floor in between, and do it in two steps. Or you can fish from both ends at the same time, using fish tapes that have hooks on the end. When they hook each other, pull the attic tape up to retrieve the basement tape. In the attic, tie on the wire bundle, then pull it down to the basement.
To pull between finished floors you need to cut a hole in the wall to drill a hole in the sill plate & fish between the floors.
See also my answer on how to pull wire to a basement or crawlspace: How do I run ethernet, speaker wire, and coax through a wall into a crawlspace?
The more holes you cut, the easier it is to pull wires, and the more fixup work you have to do.
Jay Bazuzi
  • 11,778
  • 100
  • 143
12
I disagree with the recommendation from the IT Services guy here. I really don't think Wifi is an option if you want speed. The average house has problems getting Wifi N to cover a full 1200-2000sq/ft house with good speed across it. Wifi N maybe fast, but is extremely important to be close to the router and have a good signal. Unfortunately while the signaling has gotten faster, it has not gotten better at coverage and in many cases is worse than 802.11b/g. Additionally, older homes are worse for wifi as they get interference from older construction materials with thicker plaster and gypsum board.
Truth be told, wiring the house is always best as you can deliver the absolute best speed for a relatively cheap amount. If you have electrical in the crawspace, follow that and use it as a guide to where you want to put the wires. Once you are into the walls from beneath, you can easily punch a hole in the wall and snag with a hanger.
Falcones
  • 121
If you have attic access, you can fish it up through the walls and make horizontal runs through the attic.
Alternatively, if you have an unfinished basement or crawlspace, you can go the opposite direction with it.
Other options could include running it behind baseboards or crown molding.
Doresoom
  • 15,873
  • 83
  • 122
Check your local codes. Most will allow you to run plenum rated ethernet cable through heating ducts (if you have installed forced air HVAC), and many will allow you to run regular ethernet cable through the air ducts. You can then place the ethernet jacks near the HVAC ducts, or at least get the cable close to the right area and run the cable through the wall as normal, but you'll be doing a lot less work.
If you want it to look nice and professional, though, there are long drill bits and long fishing tools that allow you to make smaller holes in your walls and run the cable without going through the process of making trenches like you describe. It's hard work, and the tools are expensive, but it may save you time in the long run depending on how much wire you have to run.
Adam Davis
  • 3,363
  • 37
The best answer for this depends on how your house is currently wired. Look for ways you can piggy-back on existing wiring runs; if there's an existing cavity with an electric wire, you may be able to fish the cat5 alongside it. If you have existing telephone wiring between the desired locations, you may even be able to use the telephone wiring itself as a fishing line.
On a lower floor, try to get your wire into the basement. On an upper floor, it's sometimes easier to drop something down from the attic. Alternatively, you may be able to run your cat5 cable through an exterior wall and outside the house. My house has some telephone wiring done that way, and it's ugly but I can see why they did it that way.
A couple of things that have worked for me:
  • Running alongside a drain vent pipe, which goes directly from my basement through the room where I needed an ethernet port.
  • Replacing an unused electrical outlet. I shut off the circuit, disconnected the receptacle and removed the wiring leading to it. Then I used the existing box but installed a plate and wiring for cat5 and coax. (This was on my first floor where I could easily drop wiring into the basement.)
Another thing you may want to consider is powerline networking. Not as reliable as hardwired ethernet, but much easier to install.
Shimon Rura
  • 8,312
  • 46
As someone who owned a private IT business, I can honestly say it is not worth the effort unless you are dead set on hard wire. If you do not have an unfinished space to run cables the effort is not worth the return. Wireless N is blazing fast and plenty secure if you configure it properly.
Buy a solid wireless N router and use wireless bridges for the hard wired devices in your entertainment center. Most computers have G built in which is backwards compatible or you can buy N cards.
Pre 80's houses were built right, it is a complete pain to run cables in them.
You may not like my answer but as an IT professional who has wired countless houses and offices it is my honest answer.
DaffyDuc
  • 165
Mesh Networks are afordable now and work much better then single good router with extender. I have 3 units in a 2000sqft home to form my seamless mesh. I did have my 70 inch 4k TV and work PC hardwired but it is not really needed to date. In a perfect world my home would have been prewired with cat6 but it was not. My house is on a slab and a retro wire job is too much work to do every room. I settled for a hybrid approach. I have Google Fiber, which is amazing.
user69054
If I had to retrofit my home I would place a high quality gutter next to my network box on the side of my house. Inside the plastic gutter I would run all of my cat5 iw (inside wire) into the attic then into the upper portion of the house. Why you ask? Well, WiFi builds up above the modem then it goes out maybe 10ft then it falls down so if we install the modem in the lower parts of the premises our WiFi upstairs will be something like -68db which is marginal to poor.
To be honest if the house has no smart panel with cat5 or better at least two in each office or living space then that house cannot be worth more than 50k in thee best neighborhood
