Using my nifty thermal camera, I discovered that my furnace closet's combustion air duct (visible in this question) is getting really hot when the attic heats up, and then (being sheet metal) it radiates that heat into the furnace closet. Here's the combustion air duct:
The furnace closet has no insulation to thermally separate it from the rest of the house, so the obvious thing happens: the heat escapes. Here's a thermal view of the wall closest to the duct when it's hot out:
In order to combat this heat transfer, I would like to insulate the stud walls that frame the furnace closet, which are currently empty. The furnace closet sits above a return air plenum that is un-drywalled, giving me a place where I could stuff something rigid or semi-rigid up into the cavities from the bottom. I am considering using Roxul mineral wool insulation batts, which I hear are more rigid and dimensionally stable than fiberglass batts. Would this work? are they rigid enough that I could actually stuff them up into the cavity? Or would this be a waste of time and money because they'll just snag and compress?
In addition, would a radiant barrier help? (asked as a separate question)
Before anyone asks, I don't want to fill the stud bays with loose fill cellulose because it would require drywalling and sealing the open sections in the return air plenum and blowing the material in from the attic, which is scary and I don't like to go up there. It's also flammable and it would be used to insulate a furnace closet, after all.
iLikeDirt
  • 12,685
  • 57
  • 98
Roxul batts do not compress a lot, well not nearly as much as traditional fiberglass. They are also pretty rigid. They can definitely go 6 feet or so in a wall cavity. I have used them to do what you are doing, when there aren't things in the way.
I am guessing you believe you don't have cross bracing or electric/plumbing or obviously this won't work. I would unroll a batt, cut to height size (possibly cut to width), push up slowly starting at top of batt. If it snags and is resisting I would cut it. Then push up with broom or something similar and just keep on going until you fill it. Even if the Roxul slides a little you can stuff the bottom to hold it. The stuff really compacts well and holds its place. Why I tend to use it in basement joists.
Also if you place a small screw in the top side of your batt (just push it in so it isn't hanging out) you can use a magnetic stud finder to see where you are at.
DMoore
  • 50,637
  • 93
  • 208
