I'm doing some work inside a wall that has some 12/2 NM cable running through where I need to put something. The cable doesn't have any additional slack for me to route it around the obstruction. I initially contemplated using a wire splice kit to add some slack, but am worried about the longevity of the device, so I want to do it right and splice it in a junction box.
However (and I'm sure this is common) I don't really want an ugly cover plate in the middle of the finished wall. Fortunately, there's an existing electrical box very close by that's used for a switched light on a different circuit.
My question is this: can I use the existing electrical box to splice cables that are on a different circuit? Or does each box have to only contain cables on the same circuit?
iLikeDirt
  • 12,685
  • 57
  • 98
You can have multiple circuits in the same box so long as you do not overload the volume of the box with devices and wires.
See this answer by @Tester101 that discusses box volume.
bib
  • 33,975
  • 68
  • 102
