I'm replacing an old mercury thermostat with a digital one.
The new unit has 7-8 connections (labeled w1,wh,r1,rh,y,c, etc.) and a bunch of instructions about how to connect similarly labeled existing wires.
But there are no instructions about how to connect an unlabelled two-wire thermostat. How do I connect the new thermostat?
Vebjorn Ljosa
  • 9,705
  • 62
  • 90
mgb
  • 1,615
Here's a good guide on thermostat wiring: http://wiki.xtronics.com/index.php/Thermostat_signals_and_wiring
Most likely, all you should need to do is connect one wire to either W for heating or Y for a cooling system, and the other to R (or Rh for heating or Rc for cooling).
BMitch
  • 43,263
  • 98
  • 204
Is it a line voltage thermostat? Do you have baseboard heaters or fan-forced heaters in the room? If yes, then you'll need a line voltage thermostat.
David Scoville
