I am installing a mini washer/dryer into a second story bathroom. I want it to be the safest and easiest installation that I can do myself. I understand the basics: minimum 4" diameter tube. Use hard tubing not flexitube, No more than 25' and subtract 2.5' for each 90 deg bend, etc... But here are a couple questions about doing it right in my particular situation.
Most dryer venting systems are attached to the wall. In my case, there is already a conduit under the floor where I am laying pipe. The conduit is between a major beam and a 12" floor plank which will be under the bathroom floor. I want to run my dryer vent in that conduit. But access to the conduit will be on the floor. Can you do that?
The venting pipe will go into the garage attic, make a 90 deg bend and then go 10' to the nearest outside wall. The outside wall happens to be above the garage roof. The vent will exit on the second story about 2' above the surface of the garage roof. Is this acceptable? ( I see other cases where people vent dryers onto their roofs. I don't know if its a good practice.)
Terry
  • 71
If you have it too long with too many bends you will be creating a fire hazzard. You need to be able to clean out that dryer vent. If you have it running 15' one way and 10' another with 90 degree turns, then you might run into fire safty issues. If you can put it up against an outside wall, make your hole there on the second story. This will save you money, reduce fire risk greatly, and you wont have to pay a small fortune to have someone run a 30' snake to clean it every year.
lazoDev
  • 733
