I own a home built in 2003. The laundry room is in the middle of the house, but also adjacent to the garage. I live in Florida.
The dryer venting system is close to the floor, turns 90 degrees, goes straight up, and into the attic. In the attic it does a 45 degree bend and travels directly to the roof. The vent is somewhere between 18 and 20 feet long.
I have had a long history of dryers lasting only a short time. I typically get about 2-3 years out of a dryer. The last dryer that died, I took apart and the dryer had all kinds of lint on the internal parts. My prejudice is that since the vent does not work very well, the lint gets blown back into the dryer, and kills it.
BTW, I regularly clean the dryer vent with one of those brush, drill and extension flexible pole things. I clean it about every 6 months and just did it the other day.
So my current dryer is acting up. When vented to the duct, clothes will dry after about four or five 70 minute cycles. When I vent directly into the garage, the clothes dry in about 50 mins. (This is done by running the flexible hose from the dryer through a door open to the garage.)
What can be done here? Should I redo the duct through the roof? Should I pursue venting directly into the garage? Who is qualified to do this kind of work? I don't think I can pull this one off myself.
Again, we live in Florida so it has not been bad leaving the door to the garage open as it has been pretty cool, but in the summer this would stress our AC unit and run up our electric bill.
Pete B.
  • 532
6 Answers6
Add both a secondary lint trap and a dryer duct booster fan. Fantech and Tjernlund are a couple brands to help you start your search.
Also, replacing any easily accessible flexible duct with rigid ducts can help prevent lint from building up.
Finally, check that the exhaust louver/vent cap outside isn't filled with lint too. Sometimes contractors use dual use intake/exhaust vents and forget to take the intake screen/mesh/filter out that is used to keep bugs from flying inside when used as an intake.
Dotes
  • 4,869
Your duct experiment and past experience indicates that the existing venting is limiting the performance of the dryer. You can't vent into the garage (see below) and being in Florida I assume you are on a slab so there won't be some alternate route into a basement or crawl space.
Your best solution may be a condensing (ductless) dryer.
This snippet of residential code outlines the problem and the solution [emphasis added]:
M1502.1 General. Dryer exhaust systems shall be independent of all other systems, and shall convey the moisture to the outdoors.
Exception: This section shall not apply to listed and labeled condensing (ductless) clothes dryers.
M1502.2 Duct termination. Exhaust ducts shall terminate on the outside of the building. Exhaust duct terminations shall bein accordance with the dryer manufacturer’s installationinstructions. Exhaust ducts shall terminate not less than 3 feet(914 mm) in any direction from openings into buildings. Exhaust duct terminations shall be equipped with a backdraft damper. Screens shall not be installed at the duct termination
[BUILDING] Building shall mean any one- and two-family dwelling or portion thereof, including townhouses, that is used, or designed or intended to be used for human habitation, for living, sleeping, cooking or eating purposes, or any combination thereof, and shall include accessory structures thereto.
Previously asked on SE
Stanwood
  • 1,599
So years later I hired someone to install a booster fan. Luckily he was a good guy and told me I didn't need that. He took the ducting apart in the attic. Sure enough it was clogged with lint. The brush and flexible pole thing didn't work sufficiently it still allowed link to build up near the top.
He cleared that out, and the dryer worked just fine afterwards. It would be advisable for a person with a similar setup to take the ducting apart every couple of years to give a good cleaning.
I won't be doing this as I since moved to a home with more sensible dryer ducting. The new home has a host of other problems but drying ducting isn't one of them.
Pete B.
  • 532
I wrote up a Q & A adventure I took with this same problem. I listed the math used and the performance considerations. Also, I ended up buying one of those pressure sensors as well to at least alert me when lint needs attention. 6 months is a good guideline but you mileage may vary.
Things like how large is your family? How often is the dryer used? Also, have you invested in a new washer? I'm not asserting that your washer is the culprit, but to be honest, as long as the dryer doesn't have a bad pressure issue or a back flow problem (like wind across your roof flowing back into the dryer) then it shouldn't be taking more than 1 drying cycle.
What size is the washer vs. dryer? Is the dryer rotting out or the motor burning out? You should also clean out the dryer itself from time to time as well.
Either way - it is probably a good idea to re-think your duct run. Use rigid smooth ducts, no screws, do not use booster fans if you can at all avoid it. Make sure your duct goes out a gable or some non-weather facing side of the house if at all possible. Since you are in FL the roof is probably ok but given your experiences, it might be worth rerouting it. Minimize bends and consult the dryer manufacturers run-length calculations as they typically exceed the general code guidelines and that is ok!
Here's my info: Dryer Venting Woes - what to do?
noybman
  • 2,035
  • 25
my dryer recently stopped working and gave me a D80 code which meant it was 80% blocked. I bought one of those long dryer brush/drill extensions and had minimal results. I watched a video of a guy cleaning his vents with a leaf blower. Worked like a charm.
C Fella
  • 175
If the vent run is too long or has too much resistance due to sharp bends, and there are little other options on where your vent could be run then I'd consider switching to a more expensive condenser or heat pump dryer.
These closed circuit dryers do not require venting as they extract and condense excess moisture into a tank or drain. As with alternative technologies, they come with their advantages but also disadvantages such as increased drying time.
hookenz
  • 992
