37
Sorry if this is a stupid question, but it doesn't seem immediately obvious how a thin strip of paper tape actually helps the taping process in drywall installation except for perhaps reducing the amount of mud needed between panels.
This, from eHow:
Embedded in a layer of drywall joint compound, drywall tape creates a physical bond between adjacent sheets of drywall. Although the bond does not significantly contribute to the structural support of the drywall sheets, the bond reduces the movement and cracking of the sheets.
Wouldn't simply mudding between the joints have the same strength without the tape, albeit requiring more mud?
JYelton
  • 2,532
6 Answers6
37
Nope. Go ahead and try it if you don't believe me! I certainly did...
The problem with wood frame houses is that they shift in weird ways as the wind hits them and as the foundation settles. The 8 foot long side of a standard drywall panel has a LOT of mechanical force to it if it moves even somewhat independently of the sheet next to it, and the joint compound rapidly turns to powder without tape to back it up. The same can happen if there is too much or too little compound or the compound is the wrong type, you can also see this problem.
This is akin to the reason that drywall is gypsum between two sheets of paper... All you have to do to break or cut the gypsum is to disturb the paper.
The best practice I've seen/used is to use Durabond to bed the tape, and then normal green stuff over it to feather the joint.
Karl Katzke
  • 7,915
  • 45
The tape installed along the length of butt-joints (bridging the gap, approx ½ the width of the tape is attached to each board) in plasterboard is put there to help prevent cracks appearing along the joint lines.
Tape doesn't shrink and helps reinforce the joint.
In the UK we traditionally call it Scrim.
Wikipedia also has a pretty good write up on Drywall.
Mike Perry
  • 1,744
Paper tape has a much higher shear strength than drywall plaster. Plaster can fill gaps, and smooth out the texture of the wall, but it's the drywall tape that holds it together as one seamless surface. Plaster isn't superglue; it needs a large surface area to provide adhesion , which is what the tape (several layers of it, usually) provides.
For surfaces that have a high chance of moving (less climate control, load-bearing wall, seams that have already cracked), drywall mesh works even better, but that is a little harder to smooth, and more expensive, so it's generally used only on problem areas.
KeithS
  • 14,367
  • 45
  • 74
My experience is tape is for bridging gaps. All purpose drywall mud does shrink over time and a thin coat over tape is going to shrink less than a thick coat filling a loose joint. Hot set mud of the type I have used doesn't shrink. The proof is in the doing, I redid the kitchen ceiling and walls of my 70 year old house and used tight joints, hot set mud and no tape. That was three years ago and no defects noted to date.
NormC
  • 79
I do punch-list for a busy builder... i have patched many many holes in walls (after having to move receptacles, after plumbers cut a hole in wall to make a repair ect... from 2"x4" to 10"x8'...). I never use tape! Never had to go back and redo any patches!
I use durabond 20 min mud... and of course use strips of wood to screw my patch to before mudding!
mark
Way too many guesses here. Drywall tape serves a single purpose: To help make the seams invisible. That it! Drywall tape does not offer an mechanical strength at all. If you skipped the drywall tape and just used joint compound to fill in the seams, the seams would become visible again after the compound dried. Joint compound shrinks! Tape does not shrink! So applied tape first, and then joint compound.....results in a smooth finish because the compound doesn't need to be as thick (aka deep) because it rests on the smooth tape.
