Although the area where I live is famed for it's white pine they grow in sandy soils. My garden has a thin skim of topsoil over six feet of compact alkaline (ph 7) clay.
My dwarf white pine is doing so poorly I think I may have to replace it. Are there any evergreens aside from cedar that will tolerate alkaline clay with full sun?
Climate USDA zone 4 with lows to -30 degree Celsius and highs of +30 deg Celsius, full sun, large greedy cedar hedge close by, southern exposure
2022 Edit: a better phrase for the soil I have is "Marine Clay". The White pine succumbed to a white scale type insect. Deciduous shrubs have done much better. The evergreens that have done well are Taxus (Yew), Thuga (Cedar) and Tsuga canadensis (Hemlock)
kevinskio
  • 62,221
  • 167
Not many conifers apart from junipers/arborvitae that will thrive in alkaline soil. There are some broad-leaved evergreens that will live.
The alkalinity of your subsoil means more maintenance, but doesn't mean you can't successfully grow acid loving plants on top. Acid loving plants have an underdeveloped root system, and obtain nutrients from symbiotic bacteria/fungi that thrive in acid soil, so these plants don't do well in too high pH, and show signs of nutrient deprivation, even when fertilized.
And also of note: most acid-loving evergreens have very shallow root systems, so if you can provide a highly organic, acidic layer in the top 6" of soil, and feed it with compost, and/or fertilizer (organic is more effective in this case), you can grow very nice conifers.
See here for more info.
If you aren't able to do this, I'll make a list of evergreens that will grow in a soil pH of 7.0, in zone 4. There aren't many that come to mind.:
I've left out the cedars (genus Cedrus) as per your question. However, these do not grow quite as well as Thuja in alkaline conditions anyway.
Your soil are wrong for most coniferous evergreens, and the hardiness zone is wrong for most broadleaved ones. If none of the listed plants will work, and you cannot work on the conditions as described above, you may have to leave evergreens and plant deciduous shrubs/trees instead.
J. Musser
  • 52,241
  • 122
  • 333
I live in zone 5 in a high mountain desert climate in SE Idaho with lots of wind. Our soil is alkaline, usually ranging in the 7.8 - 8 range. If you pour vinegar on our soil, it will start to fizz. That shows how much calcium is in the soil. Great for potatoes but not so much for conifers - it makes it difficult. I have tried many different kinds to see what I can get to work. All my trees are on a drip line and that has been the key to making sure they survive and some even flourish. I've tried some that I knew from the start would struggle (Fraser Fir) but I wanted to try anyway.
The best has been Colorado Blue Spruce. Most have been from bare-root plantings but I have done a few via pots. The potted trees survive easier but if I don't plan the bare-root Blue Spruce too late in the spring, it does just fine. Note, I can plant bare-root deciduous trees much later and have them do just fine. But the Blue Spruce does not handle transplanting in the heat at all. But once established, they grow well. Early on I only got 6" of growth/year but now I'm getting 12 - 18 inches/year.
Others: Ponderosa Pine - Only got 2 to grow out of 10 seedlings but once established doing OK. Not a fast grower - about 1/2 the rate of the Blue Spruce. White Pine - no luck Concolor Spruce - At first, they all died. I think they have to be potted or planted really early. A few have lasted two years now but growth has been slow. Fraser Fir - lost most about five are growing for the past 8 years. Growth is really slow 4 - 6 inches/year. Austrian Pine - planted 5 from pots. All 5 are doing well. Growth is like the blue spruce. I should plant more of these but they don't fill in as well as the spruce and most of my trees are part of windbreaks. Norway Spruce - tried, failed. May try potted or plant earlier. They are supposed to do OK.
Also tried Canaan fir and Douglas fir without any luck. May have been planted too late in the season.
Tamarack has survived one season. Arborvitae grow well in the area but they are not my favorite but I'm 1/2 on them.
B Savage
I believe, where I resided in Long Beach Calif, it's zone 9 (not 10 according to some). Nevertheless, I would like to share to those that live in the warmer climates my information regarding growing and caring for conifers. I am a conifer lover and tried all sorts of genus and species of conifers here in this winter warm climate (but not at all like desert) and the city's alkaline water with its high PH, which varies throughout the year.
I must have tried with varying success virtually all of the firs, many spruces, and some of the pines (south western white pine does well and it's beautiful).
The best and very well pleased with is the Colorado Blue Spruce. One normally would not think that a spruce with gone in a warm climate but mine does. This spruce does not seem to mind the alkaline city water either. I receive about 14 inches of rain a year in the area where I live. That may washout the alkaline buildup to a degree. Last year, the leader of my blue spruce grew 7 inches. The tree itself is only 3 1/2 ft. tall. So that is proportional growth and looks good. I brought another blue spruce this year(Baby Blue), have not planted yet. It's about 5 ft. tall. I look forward to watching its growth this coming spring.
One other remarkable fir I grew very successfully at my former house in Long beach and watered chiefly with the municipal WATER, is Abies guatemalensis or Guatemala fir. That species does NOT mind alkaline water as I care for it over the course of 25 years. It was so prolific in producing cones and seed that a forest emerged under the mother tree. I counted upwards of about 100 seedling under the mother tree, and many with extremely rapid growth that became tall saplings almost overnight.
I was so happy with the cone/seed production and the growth rate that I contacted a botanist at the University of North Carolina. He gave me instructions how to dry the seeds and then ship them to his university for growing experimental Christmas trees. Over all, the seedlings after out planted grew rapidly. I'm not surprised. But were not cold hardly, and many died because of that, not surprised about that either. So, after about 2 years of emails, it turns out that this species of fir was not the best for that area. But he did say in that particular year, after he out planted the seedlings, they had a bad winter there.
Then I contacted the university of Florida about the Guatemalan seed I wanted them to try. But disappointingly no replied.
Then I contacted a lady on the Big Island of Hawaii; a horticulturalist. She was interested and shipped the seed to her. Will, I wish she told me from the start, but that state because of their problem with invasive plants from elsewhere, she could not the transplant seedlings out or plant them as landscaping. That, I do not fully understand because Abies species as a rule are not invasive anywhere. Instead, she kept them in her greenhouse. I lost contact with her too and so I do not know what eventually became of the seedlings.
So there you have it with my conifer binge. I hope this helps some people.
I need to add one more bit, Noble Fir, Abies procera, is one hell of a hard species to grow, period. I have tried and tried over the years and all nobles died by root rot or by the late summer or early autumn heatwaves here. I found by experiment that this species, perhaps more than any other, needs super well drained soil. I mistakenly used potting soil, some of my own blend, but all in time died because of root rot. So, I read up on the rather hard to find information on container care for Noble Fir. Found that this species you need to use a lot of stuff in a mix: fir bark, pumices and pebbles or washed gravel, NEVER use potting soil! Of course this species can be grown only in containers here and likely anywhere else except in the Pacific Northwest. Right now, I have a few surviving Nobles in containers and they will be graduated up to larger containers this coming spring. All growing in the fir bark, etc. By the way, morning and noon sun only here in most of coastal LA County for this species). I put a lot of money into that species and got little in return so far.
I had good luck with other firs, other then the Guatemalan, like, Abies nordmanniana or Nordmann fir. I got good growth without the long winter chill as required for most Abies. I have read that this fir grows well under much harsher conditions. I recommend giving this Abies a try no matter where you live.
kevinskio
  • 62,221
  • 167
