I have some large hardy geraniums in my yard. At their best, they are about 2 feet tall and look beautiful.
However, after a storm, they flatten out and do not look nice:
We get heavy storms frequently this time of year, so the flattening happens every year. The plants do not bounce back; once they are on the ground, they stay there.
Is there any way to prevent my geraniums from flattening in the event of a storm? And if not, are there any tricks for making them look appealing again?
michelle
  • 9,569
I only do this for peonies, but I don't see why it wouldn't work for geraniums.
Stake around the plot (whatever sort of "garden stake" you typically use should be fine.) Tie string around the perimeter, and for large clumps, criss-cross through the middle as well. For taller plants, it is sometimes helpful to run two or more levels of strings. The strings can be placed and the plants allowed to grow up through them, or you can work the strings through the plants.
The garden-industrial-complex also offers steel grids for the purpose.
  • 27,360
  • 59
I found this alternate solution that might be easier, less visible, and possibly more attractive. (That is, if your geraniums have not already grown too tall for this to be feasible this year. Of course, then it won't work.)
From the link: "This rather poor photo shows how I support a hardy geranium (G. sanguineum) with a simple tunnel of bent wire mesh placed over the plant before growth start."
enter image description here Source
(I offered another answer, and I liked Ecnerwal's answer, too. It's a different answer, and so I was not sure whether to just edit my other answer or post a new answer.)
Diane
  • 1,121
I wonder if this "Flexible Tie" would work for you. It's really useful! Very bendable, and has a really soft rubber coating that doesn't cut into plant stems. It's almost like a stronger, longer version of a twist tie, and you can re- bend it quite a bit without the inner wire breaking. You could use something a little more rigid for low stakes, and then loosely loop this stuff around in the middle of the plants to offer support where the green color will blend in, without it being unsightly.
It's available near me at The Dollar Store, in VA, USA. It's really inexpensive, and there is a lot on the roll to experiment with. I don't know where you live, so you might have to look online to find a place that sells it near you. (And, if it doesn't work for your geraniums, it would still be useful to tie up other plants, shrubs and trees.)
flexible tie
Diane
  • 1,121
