16
The last couple of weeks we had unusually warm weather in the Northeast -- several days had record warm temperatures. My pair of (two-year-old, 8' high) peach trees have buds earlier than usual. If it matters, the varieties are Reliance and Red Haven, both selected for hardiness.
The warm streak is ending abruptly: it will be 12°F on Monday night.
  • Is this warm/cold transition going to prevent me from getting fruit this year?
  • Is there anything I can do to protect them from the cold? I'm thinking about covering them, but two nights below 20°F and a day with a high of 32°F seems like a long time for a tarp to keep the chill off.
bstpierre
  • 41,932
  • 118
  • 240
Unless they have passed the stage of bud swelling, they should be okay at 12F (as discussed by Clemson and NCSU extension).
Methods used to actively protect a tree from low temperatures work best under calm clear conditions. Under these conditions, an inversion layer occurs - this is a relatively stable cold air mass at the surface with warmer air above.
  1. Cover with a blanket - helps to retain heat radiated from the earth surface
  2. Spray a mist to create a fog - helps to retain heat radiated from the earth surface
  3. Wind machine - helps to mix cold air at surface with warmer air above.
  4. Irrigate - frozen water around the buds serve to insulate them from lower temperatures
  5. Place heaters under the tree.
These are all described in more detail on the "Freeze Protection Fact Sheet" published by Ontario Ministry of Agriculture, Food, and Rural Affairs. For more details on how to implement the irrigation method, see the NCSU Guide to Deciding When to Start and Stop Irrigation for Frost Protection of Fruit Crops by K.B. Perry.
David LeBauer
  • 1,057
