I recently had my window get stuck only after having it rolled all the way down. So I had to put a trash bag in its place temporarily, to keep rain from damaging the interior of my vehicle, and it was held down by duct tape. Now that the issue has been resolved, and my window is back up, I am trying to get the residue off of my car, without damaging the paint. Does anyone know how to do that?
Showing duct tape residue on my car door.
tarheel
  • 885
5 Answers5
There are "sticker removers" specifically for automotive use that should be able to soften the residue so you can get it off. I also had reasonable success with Autoglym tar remover. In either case, make sure you're using something that's safe on automotive paintwork.
Timo Geusch
  • 6,558
I am a Pilot Car driver and have taped my sign on my pick up several times. When I remove it and the glue is left I use WD-40 and it removes the glue. It alse removes tar from your vehicle too.
Jim Sholl
Duct tape — or Gorilla Tape — is awesome for heaps of things, yet it's not known for falling off neatly, especially if it's been hot.
I used to utilize CH3)2CO, at that point I changed to Goo Gone. Around five years prior, a temporary worker companion of our own said to utilize WD-40 — he swore it was better and substantially less expensive.
From that point forward, that is the thing that we've utilized. Furthermore, he was correct — it effectively expels tape buildup that took always with Goo Out of the picture.
Utilize a cloth with a touch of a surface to it — for instance, terry fabric instead of an old shirt — and douse a little zone of it with WD-40, at that point clean at the deposit. In the event that there is a considerable measure of tape gunk to get off and nothing adjacent that the WD-40 would hurt on the off chance that it ran or trickled, you can shower the deposit and let it sit for one moment before scouring.
Clearly, don't do this on anything that the oil in WD-40 would hurt! Subsequent to evacuating the deposit, I, for the most part, utilize a touch of cleanser and warm water to wash the region so it's not smooth from the WD-40. It's extremely essential to wash the WD-40 off on the off chance that you've gotten it anyplace that individuals will stroll as it is to a great degree tricky.
Nick C
  • 28,941
  • 56
  • 109
A few drops of WD40, sponge off, all gone. Hose and wipe the WD40 off with clean sponge. Does not harm the paint. Very efficient with Rust-O-... automotive duct tape. Do you believe that? Next time, I won't use stupid duct tape but paint tape, which leaves no marks, costs the same and resists rain, cold and heat.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 259
  • 508
Raulent
Rubbing alcohol or vodka work well. The alcohol evaporates but not before helping resolve the residue so you have no secondary residue from The cleaning agent which you would be left with if you used a lot of degreasers or strippers, GooGone or Aircraft remover leave an oily residue. Aircraft remover will strip everything, down to the bare metal, powder coat, urethane, oem paint which is usually urethane, etc.
Lighter fluid will work but only if you have a particular type of lighter fluid which contains naphtha, a solvent ingredient which is no longer used in many types of lighter fluid.
davidcondrey
  • 543
