Good day all,
I was driving the other night (about 3 days ago) and noticed my brakes feeling different as I had to floor it to come to a stopping point. I immediately came out and checked the brake fluid which was below the minimum mark and topped it up with some brake fluid from a gas station.
Edit: I haven't topped up brake fluid in months so I highly doubt it is leaking.
I've noticed since then when applying brakes I can hear the intake of air by the pedals and when releasing breaks also hear the air escaping sometimes and occasional squeak.
I've spoken to my mechanic and he said I'll need to get a brakes booster and cylinder. I was thinking the brakes would of only need to be bled as I have never had any brake problems before.
Is it certain that I will need a brake booster? Also what other causes can lead to me hearing the air intake and delate like noises with the occasional squeak?
Vehicle: Pajero iO Year: 1996
Thanks in advance.
The hissing of air you're hearing is likely due to a torn vacuum booster. This isn't a complete disaster but does mean you are not getting the full effect of power brakes.
The brake fluid being so low is a little mysterious. Do you see any leaks under your car, either near each wheel or near the master cylinder? It's possible the master cylinder is leaking fluid into the vacuum booster, causing it to fail.
You could try a 2nd opinion from another mechanic; it's likely you will get the same answer.
CarCrazyBen
  • 159
