I have a 2001 Pajero/Montero III 3.5v6 GDI automatic which developed a tiny hum about 8 months ago. This hum has been growing louder ever since and is at a point where you can very easily hear it inside or outside the car.
- The sound is always constant at idle or at speed.
- The sound does not change if I full lock turn the front wheels at stand still.
- The sound is only affected when the revs dip below 600 rpm.
- The location of the sound appears to be more pronounced under the front right seat of the car.
What I have eliminated
- I've eliminated the fuel pump as I can turn the key without engaging the starter and the fuel pump makes no noise.
- I've replaced the power steering fluid which has zero impact on the sound.
UPDATE 19 Jan 2024
Took her into the mechanic for the yearly and checkup. He reckons its the fuel pump. What another 4x4 enthusiast mentioned was that the pump can dislodge from its bracket and start touching the edge of the gas tank causing a sound to resonate through it.
