We have a really old toilet in one of our bathrooms which has started to leak around the tank bolts. I was going to replace the bolts and washers but the nuts are completely seized and rusted to the bolts. Due to placement I can only get about a 1" draw on a hack saw (which doesn't really cut well) so I can't easily cut them that way.
How can these be removed without shattering the tank?
Russell Steen
  • 483
I would try a Dremel type tool with an abrasive cutoff wheel. Of course you need to be careful of the porcelain. I've cut many screws and bolts this way.
If you can't cut the bolt, you may be able to cut the nut, in the direction of the bolt's axis, then pry the nut apart at the cut line.
Steve Fallows
  • 883
A great tool for this purpose and any similar close work is a ultrasonic multitool such as a Fein, Rockwell etc. Lots of tool companies are making them now. the other tool would be a hacksaw blade holder. It is not a full framed hacksaw, rather a handle that holds the blade and can get into tight places. Remember, save yourself a lot of frustration and use a good quality sharp blade, not a dime store, discount blade.
https://web.archive.org/web/20130127022010/http://www.toolsofthetrade.net/industry-news.asp?articleID=1495690&sectionID=1493
pacoverflow
  • 554
shirlock homes
  • 58,628
  • 87
  • 168
I recommend an old-fashioned mechanic's nutcracker. Search the net for "mechanics' nutcracker tool", AKA "Mechanics' Nut Splitter". Many tool vendors make these. These will split a seized nut across the flats, by hand tightening a screw that drives a hardened wedge gizmo. Works in places not accessible to other tools, like saws or grinders. It will destroy the nut, but sometimes releases the bolt without inflicting additional damage on the seized threads.
Then, if possible, replace with new nuts and bolts of solid brass or stainless steel. The additional cost is trivial. However, it is not easy to find solid brass or stainless steel bolts, to fit toilets. It's a mystery to me, why toilet manufacturers continue to install and sell replacement hardware made of steel that is only brass PLATED, which will eventually rust up, leak, and seize. Possibly, to create work for plumbers. More likely, to sell more new toilets, when perfectly good but leaky toilets get broken in efforts to remove corroded bolts with hammer blows, hacksaws, electric vibrating saws, or electric grinding wheels. Doze strategies are just too risky!
First, try an old-fashioned mechanic's nutcracker
Everything I've read seem to show the nut splitter is a good way, though I'm not sure how to use it. I also heard you can drill the bolt with a 1/16 drill bit.
I would recommend replacing with plastic screws & bolts. Which I will do. (Oddly one toilet how metal screws & plastic bolts & it still rusted on.)
Greg
