Are we required to have one in a standard kitchen with a gas range in a residential home? The big question is not how many CFM or ducted or not, just whether there is a requirement in the building codes. I live in New Jersey, US.
BMitch
  • 43,263
  • 98
  • 204
Chris
5 Answers5
Yes, and not only do you need a fan but it must exhaust outside and not just recirculate the air through a carbon filter. You are burning fossil fuels which produces carbon monoxide (among other things). This can kill you if not properly vented.
Rather than repeat what is already on this site, per the comments, see this answer for the exact code requirements for exhaust hoods.
Steven
  • 27,770
  • 56
  • 90
I am sorry but I disagree with the other answers. While I would always put an exhaust over a gas range, it is not code where I am at.
Some cities require a window to be in the room if no exhaust (and room is loosely interpreted). For instance the kitchen is in the same room as dining room as long as there is no door separating the two rooms according to local inspectors.
Some allow a ceiling fan - go figure. Just saying it isn't required in most places.
Should you? Yes.
Must you? Ask building inspector.
DMoore
  • 50,637
  • 93
  • 208
All gas-fired appliances require venting of the products of combustion! Even new appliances produce CO in quantities that can accumulate in the blood stream and cause injury or death. Get the products of combustion out of your house!
Randy Bihm
No, it is not required but is a potential hazard to not have one.
Carbon monoxide detectors ARE required in most places now and should alert you in the event your gas stove is generating a measurable amount. Using the vent whenever burning syngas, natural gas, propane, butane, liquefied petroleum gas or other flammable gas is the smart decision.
Traditionally, it has been assumed that gas stoves and ovens don't run very long and burn relatively clean, and the hazards have been glossed over in favor of convenience. Ditto gas fireplaces. However, all of these have long carried warnings that attempting to use them continuously risks build-up of combustion products, including carbon monoxide, and is not safe.
As houses have become better sealed, and less air replacement is occurring, this has become a progressively more serious concern. CO detectors can alert you to dangerous levels of carbon monoxide, if installed and maintained properly, but there is some science showing that other risks may exist too, roughly similar to "second-hand smoke".
So a kitchen vent, preferably a heat-retaining vent independent of the "vent hood" over the stove (which all too often does not actually vent to outside), is worth considering if you cook with gas. Whether it is needed depends on local code or, if code doesn't say, on how much risk you believe is involved, at least until more conclusive studies are done and regulations are updated.
For what it's worth, induction cooktops are still expensive but are a darned good compromise between the behavior of a gas range and the efficiency (and reduced indoor pollution) of an electric. I hate the traditional coil or IR-lamp based electrics; I've been quite content with my inductive. It can even do some things that no other stove can, like letting you put paper between the cooktop and pot to catch splashes (assuming the pot stays below 450 degrees, which it does in normal cooking). Biggest downside other than cost of the cooktop is that you need magnetic-steel pots, so you may have to replace some cookware. Hopefully induction will stop being a luxury option some time soon.
keshlam
  • 33,603
  • 56
  • 110
