I’ve seen a lot of questions on the internet about running wire along the length of steel beams in basements. I have a little different of a situation.
I have installed a steel beam in my kitchen to replace a load-bearing wall. I have modified this steel beam so that I can hang the floor joists on it. This means I’m unable to use steel beam clips that I have seen online to adhere wire or conduit to it (see image)
I’m beginning to run 14-3 wire into the ceiling for my lighting, but would love to cross my beam in order to avoid going around or into the basement with the wire (feels excessive and messy). Ideally the wire and whatever I use to secure it remain above the bottom of the floor joists, since the whole reason I put a steel beam in was to have a flush ceiling between the rooms. The joists hang about 1/2" below the bottom of the beam.
Any ideas for how I could protect and attach the wire to this beam?
NOTE: Any concerns or questions about the joist hangers can be discussed here. Worth noting I have since drilled new holes in the few hangers that had questionable nail placements and drove new nails in.
