This GFCI receptacle claims, as far as I can tell, to be multiple things, and I am hoping someone here can clarify for me.
Here is the sticker.
You can see that it says 2 Pole, 20A, 125v 60Hz.
And here is the front of it
If you look ignore my red marker "15" and look at the text that is actually structurally part of the unit then you will see that it says 125v 15A 60Hz. You will also notice the "Spec Grade" text on the right.
And on the back
You can see that it has two each of hot inputs, hot outputs, neutral "inputs", and neutral "outputs". That plus the grounding screw makes for nine connection points.
I see no evidence that this is a Frankenstein item or a kludge or something like that. My Klein Tools plug tester will fit both outlets just fine, and the plates for catching backwiring (NOT backstabbing) function just fine. The bonding screws are the correct colors, and Line and Load are clearly labeled. The prong holes on the front are clearly for a 15A receptacle.
Am I looking at a 15amp GFCI with a wrong sticker (that will be fine to put on a 15amp circuit) or a 20amp GFCI that was mislabeled at the factory (that I definitely should NOT put on my 15amp circuit)?
