22
I have a squealy floor below my carpet on the 2nd floor of my house. It sounds like the subfloor under the carpet is moving up and down a little and makes this awful load squeak when I step down on this specific location. It can be reproduced at will.
mohlsen
  • 6,359
  • 39
  • 47
Fixing a squeaky floor beneath a carpet is a fairly complicated process that's probably best illustrated with video. This Old House provides a wonderful tutorial.
The procedure demonstrated at that link does not require you to pull up any carpet and uses scored screws to hide your work (the head snaps off) . This seems to be the most hassle-free way to do what one might expect to be a huge job.
rogerdpack
  • 1,132
  • 39
Mike Sherov
  • 1,489
The squeak is due to flooring sliding up and down on nails that have loosened with time. Putting more nails is a temporary fix. Screws will hold tight and resolve the issue for a long time.
kfrew
If there's movement you'd do best to pull back the carpet and nail down the subfloor. Hopefully the squeak isn't in the middle of the room.
I had a squeaky floor at an old house, had to pull back a large chunk of carpet and drive a few nails through the floor to anchor it down.
Best of luck.
